주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.4 GHz 프로세서, 1280x800 픽셀 LCD, 149 ppi 멀티 터치 디스플레이를 갖춘 10.1인치 Samsung 태블릿 컴퓨터입니다. 기기 모델 번호는 GT-N8013ZW입니다. 2012년 8월에 출시되었으며, 기기 수리 과정은 직관적이고 간단합니다.
Boot Loop Issue - ODIN MODE
Hi All,
Looking to repair my Samsung Galaxy Note 10.1. It's stuck on the boot loop issue.
I have tried everything: Hard/Soft reset, connecting to the comp, booting into recovery mode, remove battery, nothing works.
I tried to flash the BIOS as recommended online, although my comp doesn't find the device when connected via USB. I also tired to boot it into recovery mode to wipe the device, but i only get the option to boot into ODIN mode.
At a bit of a loss here... any suggestions or ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 4개:
Have you tried re-flashing the OS via Samsung Keyes?
Or re-flash via ODIN itself?
The actual ROM to flash in ODIN can be found at XDA-Developers.com, but I need to your exact model number to post a direct link.
의 공유
Or Sammobile or Updato.
의 공유
OK update.
Not sure how or why, but tried the tablet out on my friends laptop running Vista and drivers and download and device comes up on ODIN.
What do i do next? Ie what ROM do i need to flash my device and fix this boot loop issue.
Also model number is: GT-N8010
의 공유
hi please i have a note 10.1 2014 edition and whilst downloading custom os the cord slipped out of it and now it wont register in odin309
plz help
sm-p605
yours cinserely Jarred
의 공유
댓글 달기
답변 2개
Try to flash with Z3X tool with 4 files
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
That requires a Z3X box to do so, but if a flash of Samsung stock firmware fails, it's usually the tablet that is no good.
의 공유
could be EMMC error, you can fix it if you have easyJtag tool box
의 공유
댓글 달기
I have the same problem and I have tried all the best I could have done in a few days but everywhere I found something in the hope that I can do it to fix it so on these tablets leaving the memory EMMC is still the servicebox option (Z3X, RIFF, OCTOPLUS ) but my opinion is the same and it is only a temporary solution when it starts to blink it will be still. Best to replace the BGA eMMC flash or the entire motherboard
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nathan Thomas Gunn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 8,687
