주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Lightning connector install - antenna connector?
Have purchased the lightning connector kit and removed my old one, now installing the new one. I just can't get that dog gone antenna cable connected to the socket. I worry I've broken it, but it LOOKS like it's intact. Unable to tell.
Any secrets to getting that connector attached?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I usually hold just below the head (the actual connector) with tweezers, align it and then apply pressure with another fingernail.
Now, if you have tried several times, you may have deformed the connector. It should be nice and round; otherwise, it is difficult to mate.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
i prefer to use my tweezers to hold the component still on the metal neck of the connector, then use the corner of my pry tool to pressure the component into place. you should hear a firm Click, that lets you know it is set. if you dont get the click, there is a possability that it was milled too loose, or expanded by continuously trying to fit it. that being said, if it doesnt come off with a light tug, then it should be in place.
I hope this helps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
keimel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 65
