주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Fire, Fire 또는 Amazon Fire는 Amazon에서 출시한 Android 기반 미디어 태블릿으로 멀티 터치 컬러 디스플레이를 탑재하고 있습니다. 수리 시 스크루드라이버와 지렛대 도구만 있으면 됩니다.
orange screen no response
when i turn on my Kindle fire the kindle logo appears for a few seconds then the whole screen turns orange and nothing works, this is the second kindle i have had with the same problem, seems to be software but usb connection not working either.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 4개
Any luck? I have the same problem.
의 공유
My screen turned orange, but that’s not all. The real problem is that it shows a partially filled page to Register my Fire. Password missing, so I write it, but nothing happens. Is non responsive.
If I try “forgot password” it sends an e-mail with an OTP but when I enter it, again, nothing happens.
I tried to reset the Fire from the Amazon page, but it doesn't work… apparently it can’t connect to the Internet.
Can any one help?
의 공유
Mine starts up goes blue and then goes Kindle fire again then goes to bootloop
의 공유
My Amazon tablet has went orange on my screen. Everything is working and letting me do things but it is so annoying and I need help!
의 공유
댓글 달기
답변 1개
가장 유용한 답변
swipe down from top of screen
select settings
select display
select "Blue Shade"
look down at "Automatic Activation
to the right side of the screen there is an oval with a dot to the left
Swipe this dot to the right. It will restore your screen to the normal color
이 답변이 도움이 되었나요?
점수 10
댓글 7개:
Thanks so much. I'm glad I came across you before I had a chance to go crazy. It was nice and super easy.
의 공유
I have to thank you too !!!!!
의 공유
Same here - usually when I try peoples online suggestions for various things, the problem still exists. Yours was simple and worked.
의 공유
Thank you!!!back to normal color
의 공유
Thank you so much. I knew how to brighten the screen but, the screen stayed orange until I read your instructions. It saved us a trip to the computer store and money!!
의 공유
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Diana Osborne 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 20
전체 시간: 22,604
