주요 콘텐츠로 건너뛰기
A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
15 질문 전체 보기
How to do a factory reset?
I've gone thru all the options on the Sony eSupport pages, it's a no go.
The power lite goes on, but nothing else works. The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off, which may be an error code? The power lite goes off only if I remove the battery.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@paulieh01 this should work to reset your camera:
"The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off" is an indicator for the memory card. You may have some problems with the card. Remove and/or replace it it and see if that changes anything.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Paulie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 12
전체 시간: 2,102
