주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
up-volume button has lost its "spring" and "click"
the down-volume button on my iphone 4s works fine.
the up-volume button is kind of sunk into the phone, does not spring back out anymore, and does not "click" when you push it. it just seems dead and does not control the volume any more.
i had to turn on "assistive touch" and control volume on the touch-screen now, but would like to get the button working again!
any thoughts on exactly what part (s) i need to get and replace in order to fix this?
thanks!
pete
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Volume switch flex cable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
@petehy , Peter the 1st link is a guide to show how to disassemble the device to check for possibly dust/debri/gunk or fault, which could be the headphone jack/volume control cable available( I believe what Tom is also referring to) for purchase at the 2nd link. Good luck.
iPhone 4S Headphone Jack Cable Replacement
[연계 제품이 누락 또는 비활성화 됨: IF115-013]
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is what the actual buttons look like on the inside (to the left in the image):
http://applepartsstore.com/media/catalog...
The yellow plastic covers with a tiny black "tit" in the middle of is the only thing you need to replace to resolve your issue. It's way easier than replacing the whole headphone jack part, and it shouldn't take you more than 5-10 minutes if you have experience in repairing phones. What's happened on your phone is that the tiny black "tit" in the middle of the yellow plastic has been worn out or, more probably, completely loosened from the yellow plastic. Underneath the yellow plastic there are two identical metal plates stacked on top of eachother, and it's very important to make sure that there's still two of them there when you replace the yellow plastic part.
You simply order a headphone jack for an iPhone 4 or 4s, it doesn't matter which one, and carefully peel off the yellow plastic part from your old volume-up button and discard it, and then carefully peel off the same part from the new headphone jack flex and move it to the headphone jack flex in your phone. Put some pressure on it with your fingers so that it sticks, and then put your phone back together.
Feel free to ask questions if any of this is unclear, I'm too restless to read through what I just wrote right now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Peter Humphrey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 349
