이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 4개
I just replace the ink but can't print because the printer doesn't seem to grab the paper, the paper just went in half way and nothing was print on it.
If you have the HP 1515 can you copy or scan a document OK using the printer's control panel?
If it works OK this way, can you try a test print from the computer that the printer is connected to? (usually found in the Printer properties area in the computer)
댓글 4개
adnan abdul ajis 의 공유
Hi @ adnan abdul ajis,
jayeff 의 공유
hey my printer hp 1515 just wont print . i press print from my laptop and nothing happens
meera ali 의 공유
hey my printer error, it can scan but its cant prin, and i can open the properties..
Rikrik Channel 의 공유
