주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP에서 판매한 대중적인 노트북입니다. 여러 가지 구성으로 출시되었으나, 모든 모델이 동일한 기본 폼 팩터를 갖추고 있습니다. G60 뒤의 숫자는 해당 노트북의 공장 사양과 판매처를 나타냅니다.
Loose Power Cable- can it be fixed?
I have an HP notebook, model G60-535DX. The power cable, when plugged in, is very sensitive to touch. The light easily goes out (the small silver charging light next to the jack). The cable, when inserted, feels loose. SO, I think the jack is loose from the mother board. HP is out of warranty and I am traveling. Can I open case and easily fix this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
1. Test your AC adapter with a voltmeter and figure out if this is bad adapter cable OR bad jack.
If it's bad adapter, replace it with a new one.
2. If it's bad jack, you'll have to disassemble your HP G60 laptop and replace the jack. It's not soldered to the motherboard. You can simply unplug the damaged jack harness and plug in a new one. Take a look at the last picture in the guide I mentioned.
3. Alternatively, you can find laptop disassembly instructions in the official HP service manual. Find your HP laptop and download the manual. Go to parts replacement procedure. In the same manual you can find HP part number for DC jack harness.
Same instructions apply to Compaq Presario CQ50/CQ60/CQ70 and HP G50/G60/G70 laptops.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
These DC sockets are NOT a unit soldered onto the circuit board, but are on a flying lead and then plug into an edge connector elsewhere. So do not expect a lose jack to mean the solder connection is broken- as the whole jack case is "floating" from the factory design! ( I took my laptop apart expecting a cold solder joint and it is not connected that way)
The wire leads that are soldered onto the back
Of the jack case may be loose or broken from the jack wiggling around- or the contact pins inside the jack that detect if the peer supply is plugged in etc, may also be worn down or bent out of position. Either way, you can replace the complete assembly by unplugging the unit - no soldering is needed. (unless you see an obvious wire break from the back of the jack case assembly)
I suspect a battery that fails to charge has a bad contact inside the assembly if all wires look intact.
Joe
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
That is correct and was already answered appropriately by Laptop Repair Guy " It's not soldered to the motherboard. You can simply unplug the damaged jack harness and plug in a new one."
의
댓글 달기
hp envy loose power plug
buy usb dongle on ebay £1.25 . plug dongle into usb port on the sames side . use a tie and secure
power cable to the dongle . power plug will not fall out.
23/01/2019 by james
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sunshine 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 25
전체 시간: 27,341
