주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Vivoactive HR 스마트워치 수리 정보. 2016년 2월 출시. 모델 번호: 010-01605-03.
display broken / need replacement display
Hey everyone,
unfortunatly I crashed the display of my Gamin Vivoactive HR.
I called Garmin for a replacement and they told me its about 150€.
Is there any other possibility to replace the display by my own?
Buy the display seperatly anywhere ?
I am thankful for every help
Best regards,
Andreas
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
Hey everyone,
Best regards,
Cesare
의
댓글 달기
답변 5개
가장 유용한 답변
Hi Andreas,
I have a used display. Are you still interrested?
이 답변이 도움이 되었나요?
점수 2
댓글 7개:
Is the used display still available?
의
Yes is still available
의
Hey there, I am also interrested. Could you please tell me if the Display is still available? You can also directly contact me via gerrit.puddig "@" conjin.de. thanks
의
Hi.
May I know ifthe display still available?
의
Leonidos didn't answer me. See my Question above...
의
댓글 2개 더보기
댓글 달기
I had to open my Vivoactive HR because it wad died, what I saw it was water inside device :(
Now I know that it is no super easy way to open this Garmin.
1st. you have to unglued plastic part where buttons sits
2nd. using this hole (buttons whole) you should gently push screen using something like screw
  • be careful with electric tapes (there are few) it is easy to broken (tear) using only a little force
  • there is only 1 screw on button board
Maybe my photos will help anybody to repair this Garmin.
이미지
이미지
이미지
이미지
이미지
이미지
이미지
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 달기
이미지
이미지
So I have a vivoactive hr and yes a crack screen n unresponsive to touch too. Opened it up( direct from screen) and it wasn’t that hard too, but I really hope they start selling the screen so maybe one day I can replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
How did you get the screen off? Trying to get it off without completely destroying the unit.
의
It’s being hold down by adhesive tape so use heat
의
댓글 달기
You can buy a display there :
https://www.smitacn.com/lcd-screen-for-g...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Good to know for future, but in not much more you can buy used but working device :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andreas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 23
전체 시간: 5,217
