주요 콘텐츠로 건너뛰기
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
46 질문 전체 보기
My 1990 Honda accord EX-R hood latch is bent inward, how do I fix it?
I rear ended someone a couple weeks ago and i got a new hood for my 1990 honda accord but my hood wont shut flush. I looked at my hood latch and it is bent inward, is there anyway i can fix it myself, if so, how?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
diego tamesis , If you are talking about the hood latch on top of rad support they can be bent out fairly easy. Tie a rope/chain/cable around the area of the latch/cradle and the other end wraps around a 2x4, put a rag between 2x4 and bumper, now use the 2x4 to pry the hood latch/cradle into correct position. May have to fine tune with a heavy hammer and board. Ifyou are not removing any thing such as radiator,A/C condenser,etc. take your time and be careful as you do not to damage other parts. See the link below, same idea, just not as drastic. Good luck.
https://www.youtube.com/watch?v=Zr4grivK...
해당 답변은 도움이 되었습니까?
점수 4
댓글 7개:
Thank you so much! appreciate it
diego tamesis, your welcome, I have actually had to do this before on a friends car. If you like the answer, accept it thanks.
Hi @lpfaff1 ,
Is a 'heavy hammer' also known as an American screwdriver where you are as well? ;-)
jayeff, :-))) I have not heard it termed that way, but maybe by some!
I had heard of that but the urban dictionary has: http://www.urbandictionary.com/define.ph...
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
diego tamesis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 11
전체 시간: 1,151
