주요 콘텐츠로 건너뛰기
Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 질문 전체 보기
What can I do to fix my video card?
My computer first started acting up after I downloaded an update for a game. The game then caused me to randomly have bsod which did not provide me any error code. My monitor has started cutting out every once in a while now and the entire screen shows a random color. To reverse this I have to put the computer into standby mode and reactivate it. I appreciate any help you can offer.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
My computer is a Compaq Presario V6000 with an intel integrated chip set.
댓글 달기
답변 6개
선택된 답변
You can try to reflow the GPU chip it is fairly easy if you know what you are doing. A more permanent solution would be to re-ball the soldering on the GPU chip you can youtube it so you can get an idea of how to do it but the tools needed would probably cost more than a new laptop. I have fixed this problem on numerous laptops by just doing a reflow so that is probably what I would do. Good luck!!
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Go here and see if your machine has the Nvidia issue: http://www.nvidiasettlement.com/affected...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
My computer wasn't on the list. It has an Intel integrated chip set.
댓글 달기
How to fix video problem on HP laptops
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Kiba32b, you might want to check here will not power on about how to reflow and fix the issues that might be causing your problems. Good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi,
Compaq Presario V6000 are known for a big hardware problems with the GPU and the Mainboard.
I have one, my laptop still have a black screen when booting... nothing on the screen.
So I took the mainboard, remove CPU, RAM, and remove any plastic item ( eveything you know it can melt )... And put the mainboard in the oven ( at 160°C ) for 3 minutes.
When 3 min past, be careful, handle the mainboard carefully. Put in on your table.
Wait until the mainboard is cool.
Replace the mainboard carefully.
=> Test
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have this game and sometimes when I start to play it,the game freezes on me.Would this be a problem with the graphic card or would it be something else.??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kiba32b 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 12,964
