주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion 시리즈의 일부인 HP 노트북, HP Pavilion dv6000에 대한 수리 및 문제해결 정보입니다. 2007년 4월에 출시되었습니다.
will not power on
when pressing the power button nothing happens. The pc is receiving power.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 15
댓글 3개
please replace the cmos battery 2032 beside memory
의 공유
So simple.
Thanks
의 공유
That is the asl HP Laptop...
의 공유
댓글 달기
답변 4개
선택된 해법
This is a well documented prob with this series of notebooks and if you do a search on the Internet you'll find lots and lots of unhappy and frustrated people. The problem is the motherboard, and the symptoms include loss of bootup, VERY slow bootup, WiFi stops working, etc. is simply that the MOBO board overheats and fries the video driver chip. The cooling design of this PC is inadequate.
You might try this to verify.
1. Take the battery out and unplug the charger
2. With the computer lights OFF, press and hold down the power button for 15 seconds
3. Plug the charger back in and start-up the computer
to fix the problem you will have to either reflow the graphics chip, which may or may not work. Best would be a complete reball.
이 답변이 도움이 되었나요?
점수 6
댓글 1개:
Thanks bro. It did actually work for me ! 8 years later!!
의 공유
댓글 달기
CHECK 1:
Remove power connection, remove battery, replace battery and try again. Might fix your problem by now.
IF NOT FIXED YET:
If it tries to turn on but keeps cycling in 3-10 second reboot intervals, turns on for 3 seconds then reboots and does it over and over again. 'CHECK 1' again then. 'CHECK 2'.
CHECK 2:
As you hit the power button, after having done 'CHECK 1', hit escape a couple times this should force a boot under any condition.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I found a problem with the power button ribbon connector I put some scotch tape on the back of the ribbon cable then reinserted it and now she works!!!!!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
i hav try all this ways but its no working dowing the same
의 공유
댓글 달기
Are you asking about HP Pavilion dv6000 notebook?
1. Could be memory failure. Try removing memory one by one.
2. If it's not bad memory, most likely this is known GPU failure.
You can try fixing (temporarily) the GPU problem using this trick:
How to fix video problem on HP laptops
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 57
전체 시간: 62,621
