주요 콘텐츠로 건너뛰기
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 질문 전체 보기
Replacement headlight fuse location
It would appear that the driver's side headlight fuse is blown. The problem is that neither fuse box has an indication as to what fuse belongs to the headlights.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
Where is the fuse located inside the car or under the hood
Fuses are good, what else could prevent hi & lo headlights from lighting up?
mpgrote@comcast.net
Where are the headlight fuses??
댓글 달기
답변 2개
선택된 해법
Okay just checked in the service manual and it looks like the following: 30 headlamp L low, 20 headlamp R low, 28 headlamp L high, 27 headlamp R high, hope this helps.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
how does this help me find the fuse and or fuse box
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
vrok73 it does not. It was not meant to help you. It was meant to help the OP. If you need some help with your vehice, just use this link and let us know what you need.
The fuses are in the Power Distribution Module located in a black box behind the fuse box on passenger side of RHD vehicle. Has four clips and very hard to get off! Has all the fuses that are not mentioned in the other three fuse boxes.
댓글 달기
답변을 추가하세요
Frank 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 15
전체 시간: 33,237
