Replacement headlight fuse location
It would appear that the driver's side headlight fuse is blown. The problem is that neither fuse box has an indication as to what fuse belongs to the headlights.
좋은 질문입니까?
좋은 질문입니까?
Okay just checked in the service manual and it looks like the following: 30 headlamp L low, 20 headlamp R low, 28 headlamp L high, 27 headlamp R high, hope this helps.
이 답변이 도움이 되었나요?
how does this help me find the fuse and or fuse box
이 답변이 도움이 되었나요?
vrok73 it does not. It was not meant to help you. It was meant to help the OP. If you need some help with your vehice, just use this link and let us know what you need.
The fuses are in the Power Distribution Module located in a black box behind the fuse box on passenger side of RHD vehicle. Has four clips and very hard to get off! Has all the fuses that are not mentioned in the other three fuse boxes.
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 33,824
댓글 3개
Where is the fuse located inside the car or under the hood
Aretha 의 공유
Fuses are good, what else could prevent hi & lo headlights from lighting up?
mpgrote@comcast.net
Marv 의 공유
Where are the headlight fuses??
Phill Taylor 의 공유
