주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
How to fix water damage
i am a kid and i did not want to tell my mom about it and they say rice help get a blow drier and have the sims card out and every thing then have the blow drier on it for like 15 -10 mins
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi MaTasia Truss the kid, listen to the old turkey, he knows what hes talking about. Tell your mom your going to need her help. 'DO NOT USE RICE ' Dont use that hair dryer either it will blow the water into other places that may be dry and make things worse . Do not to turn the phone on to see if it works until its cleaned out . If you are not willing to take the phone apart you can leave it to dry out naturally by itself . Remove the sim card leave the tray out and put it someplace dry and forget you have it for a few weeks. Then try it and hope for the best but understand it will not work for long it will now begin to corrode on the inside and will soon die a slow and annoying death . So tell your mom
이 답변이 도움이 되었나요?
점수 3
댓글 달기
가장 유용한 답변
MaTasia Truss you better let your mom know because you will have to work on your phone. You want to save the rice for cooking, it has no place in any electronic repair situation. It does not work and can make things worth. do not use rice
The very first thing you want to do is to not try to restart the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using this guide Then clean it with +90% isopropyl alcohol. Follow this guide, and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. Hope this helps, good luck.
iPhone 이미지
안내서
Repairing iPhone Liquid Damage
난이도:
어려움
1 - 2 hours
iPhone 5c Logic Board 이미지
안내서
iPhone 5c Logic Board Replacement
난이도:
조정
1 - 2 hours
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
MaTasia Truss 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 130
