주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월 16일에 발표하였으며, 모델 번호 A1347 및 EMC 2840으로 식별할 수 있습니다.
Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
의 공유
@yannick17 - Review my answer for the details
의 공유
댓글 달기
답변 2개
선택된 해법
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Mac mini Late 2014 하드 드라이브 케이블 교체 and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini. 이미지
제품
$29.99
Mac mini Late 2014 PCIe SSD 케이블 이미지
안내서
Mac mini Late 2014 PCIe SSD 케이블 교체
난이도:
조정
15 - 20 minutes
Mac mini Late 2014 하드 드라이브 케이블 이미지
안내서
난이도:
조정
1 hour
Mac mini Late 2014 하드 드라이브 트레이 이미지
안내서
Mac mini Late 2014 하드 드라이브 트레이 교체
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
의 공유
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
의 공유
댓글 달기
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
댓글 달기
답변을 추가하세요
tomtcs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 31
전체 시간: 2,028
