주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년에 출시된 Android OS 태블릿이며, 모델 번호 T10으로 식별됩니다. Tagital T10은 Wi-Fi를 지원하는 터치 스크린 기기입니다.
Optimizing Apps on Android Device
When I turn on device, it goes through the normal procedure, to the point when Android window comes up.. it slowly darkens to light as they do while loading the Apps.. then it goes to a screen that says " Optimizing Apps" . at this point it may start at Opting 1-10.. or 25 -77, or what ever never the same twice... (After many attemps) then it completes and goes back to Android Screen and just sit there.... eventually shutting down.. I have pushed the (reset) button with a paper clip.. it does nothing but start the cycle over..... Any help next to turning this into a Frisbee would be helpful Thanks... Jeff
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jeffntoni 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 25
전체 시간: 398
