주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 2월에 출시된 Nintendo의 첫 3DS 휴대용 게임기이며, 모델 번호 CTR-001로 식별됩니다.
3ds top screen not working
My top screen is black and the bottom touch screen works does anyone know why I am having this problem with my 3ds?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 달기
답변 4개
가장 유용한 답변
@colhot ,colette , Maybe there's a problem with the cable connection to the top screen that's causing this, as the hinge moves it may have damaged cable/wire or loosened connection. Below 1st link is to disassembly guide for upper display to enable you to get inside device to check and clean all connections/reseat them and check for damage. Clean all the connections with a Qtip dampened with 90%+ Isopropyl Alcohol and reseat for good connection. If all connections,wire,etc look good the LCD likely faulty. If needed the 2nd link is for more guides for your device. The 3rd link is a replacement lower LCD display if needed which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nintendo 3DS 상단 LCD 교체
Nintendo 3DS
Nintendo 3DS Upper LCD
Replace a broken or damaged LCD in the upper half of your Nintendo 3DS portable game console with this part. 이미지
제품
$34.99
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
I followed David Godson's guide for replacing abxy buttons but now the top screen won't work...
Please help.
의
댓글 달기
I think it is a good question
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Is this expensive to fix??? I want my parents to fix it for my 13th b day!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
my top screen is black and i can’t see what am i doing when i play a game because my top screen dose not work do i need to replace it are something.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
colette 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 104
전체 시간: 27,534
