주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Visual Land Prestige Elite 8Q은 Visual Land에서 생산한 8인치 Android 태블릿입니다.
How do I do a factory reset?
Factory reset for a visual land prestige elite 8qi
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 4개
I got a used tablet and it will not let me log in to my account to set it up and it keeps asking for a previous email that was sync to it before and I don't know it
의
I accidentally hit the button for the blind I was trying to dim my screen and I hit the wrong button now it talks to me and gives me commands but it doesn't light up I can't get nothing to light up on the screen cuz I hit for the blind and now I can't get back in it to turn it to take it off of the blind
의
Don't know what happened mine. It is not coming on at all. Tried all suggested fixes of holding power volume button. Does not work. How do I n reach manufacturer?
의
How do I factory reset my tablet if my password won't work
의
댓글 달기
답변 2개
가장 유용한 답변
Hold both volume up and down buttons together with the power button for about 15 secones, until you see the presitige logo. Pick the option: wipe data/factory reset and then select yes. When it states : wipe data complete, go back to top and choose reboot system. Navigate using volume up down buttons and select with the power.
이 답변이 도움이 되었나요?
점수 8
댓글 4개:
What if you are locked out of the tablet how do you factory reset
의
I just did what the original text said and it worked
의
How about if u don't know the password
의
make sure the device is off. Then at the same time hold all three down the power the volume up and down and when you see it come on release both vol buttons and then instantly press them again do not let go of the power . hold for 3 sec and then release all you welcome
의
댓글 달기
Hi,
If you have access to the device functions you would go to Settings>Back-up & Reset>Factory Data Reset.
The link below is the PDF version of the user manual:
https://visual-land.com/downloads/androi...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I installed a security code and now the tablet is rejecting it. That leaves me with no way to access the tablet to reset it. Is there a way to be able to bypass this code to reset my tablet?
의
댓글 달기
답변을 추가하세요
Denise Jolly 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 10,213
