주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
다양한 속도 설정과 부착 옵션을 갖춘 Dremel의 로터리 툴입니다.
Collet Nut Frozen on Shaft
I have not used this Dremel tool in some years. The Collet Nut is frozen to the shaft and cannot be loosened to insert bits. How can I loosen this? Short of replacing the entire shaft? I have already soaked the part in coke and it has not loosened.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
선택된 해법
A lot of these had a button which locks the shaft in place allowing you to put pliers on the collet and turn it. See if yours has such a lock.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
No kidding. That's the problem... the locking button does not hold the shaft in place and it slips out.
의
댓글 달기
@knightowl12 ,Jeffrey, If collet lock button not holding sufficient, you may have to disassemble the Dremel(link below) which will allow you to access the shaft which you can put vice grips on to hold the shaft while using pliers/vise grip on chuck to loosen collet(if able put a couple drops of penetrate oil to run down bit to collet jaws for 30 min. before starting the repair).
Dremel 8200 분해
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jeffrey D Sage 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 62
전체 시간: 12,923
