주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mazda의 2세대 Mazda 3(Mazda3 및 Mazda Axela라고도 함) 세단 및 해치백 시리즈입니다.
Revs too high after service
After taking the car for a second service to reduce the revs I still find them higher than when I bought it. The mechanic said all he did was reset the computer. Is there a way I can change the computer settings or how would I go about changing the revs?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
countparas, You can not change the cars computer settings with out special scanner/software/knowledge as normally found at a dealership or well equipped shop.
Ask the dealer ship/shop to show you the cars idle speed specifications cold/warm(operating temp.), if idle speed is in the parameters should probably not adjust further. If not in parameters they should correct the issue. Whether by adjustment/faulty sensor, vacuum leak,throttle body sticking/dirty or having to change program in computer. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Your mechanic needs to set the rev limiter on the computer.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
countparas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 1,644
