주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2005년에 출시된 61건반 터치 감응식 휴대용 키보드인 Yamaha YPT-300입니다.
Power pack over heated
The power pack made a noise and stopped working, it was unplugged and disconnected from the keyboard, i put new batteries into the keyboard, but it's not working, does the keyboard have an internal surge protection, if so can it be fixed?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Some Yamahas have a current limiting polyswitch, but if you have tested the unit with a different power supply and it still doesn't work, there is a good chance yours doesn't or it did not help. There is a good chance that your power supply is a switch mode type so once it failed it best to buy a new one, but before you plug it into the keyboard you will want someone to test it to make sure the voltage conditioning section of the dc in pcb is not shorted. If it is, best to replace the pcb or get a. Per job repair.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ian Clarke 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 18
전체 시간: 410
