주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon의 Kindle Paperwhite 시리즈 중 이 버전은 2015년 6월 30일에 출시되었습니다. Kindle Paperwhite 3세대는 Wi-Fi가 가능한 6인치 300 PPI 읽기 전용 디스플레이 태블릿입니다. 지정된 모델 번호는 DP75SDI입니다.
Frozen unresponsive screen. Can it be repaired?
Hi!
I have a Kindle Paperwhite, 6" High Resolution Display (300 ppi) with Built-in Light, Wi-Fi - bought in October 2015.
Kept well, it hasn't fallen down, nothing untoward. Stopped working. The screen had an erratic display for a while, and has now stopped responding.
Can anyone help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
I am having the same problem, could you find a solution for this? Please let me know.
댓글 달기
답변 3개
가장 유용한 답변
I had this problem with an e-reader and it turned out that it quit charging. After placing the e-reader on a new charger it started working again. The models we use in our school are all nooks but this may help you out too.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hey! Thank you so much. But this one is charging. No problems with that. Just that the screen gave an erratic display and then stopped responding. I am trying to understand if it is a screen or motherboard issue. Will try and fix it accordingly.
댓글 달기
Did you find a solution to this? I am having a similar problem
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
... me too!!!
@skeeve205 could you please let me know if you found a solution for this?
댓글 달기
Try tapping (or knocking with your nail) in the bottom right corner of the front. (Edit: you can also try bringing a magnet to that corner and bringing it away)
If it responds, then I have a workaround for this, that I’ll publish as a “technique” guide within the next few days. (EDIT: here it is!) The only problem with that guide is that it will no longer respond when opening/closing the cover
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Anamika Das 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 5,224
