주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
250GB HDD와 Wi-Fi가 내장된 클래식 Xbox 360의 슬림 버전입니다. 수리를 위해서는 정교한 지레질과 특수 도구가 필요합니다.
no power to my console
i tried to turn on my new xbox 360 slim and nothing. i order a new power supplise and still nothing. the light on the power supplie is orange and the when i press the power it turns red. I tried to send it to xbox and they refuse to fix do to bad sticker. I dont know what to do,I only had it for two months, I dont want to buy a new one. help..
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 3개
did you pklug it in
의
did you turn the switch on the power point
의
My dog peed on mine and it no turn on pls help and me game is stuck inside
의
댓글 달기
답변 7개
가장 유용한 답변
What did you open it for? Check for any damage to the motherboard, and any metal/solder that might be shorting it out. The power supply is turning red to protect the console, so it might not be permenantaly damaged.
이 답변이 도움이 되었나요?
점수 5
댓글 2개:
I open it after everyone refuse to fix. I check the mother board and I didnt see any damage.Is there any way I can track the power through the board to see where it might have problems. or know of someone I can take it to, that can fix it, I spent 400 on it and only played it fr two months.
의
Chris meant what did you open it for before sending it back to Microsoft. They refused to fix it for you because it seems like they felt like you opened it before sending it to them. Is this the case?
의
댓글 달기
No power is normally caused by either a bad Mosfet or a bridged connection. In the traditional xbox 360, if you have no power due to a bad Mosfet (power regulator), it will turn on and red ring, reading codes 0001,0002, or 0003. I am not sure how slim error codes work so I couldn't say for sure the source of your problem.. but if you hadn't opened it before I would say check inside of the USB ports and make sure nothing in them is bridged.. also look for bridged connections on the motherboard. Other than that, you'd have to check each mosfet for correct power output and replace the ones that are bad and hopefully that would fix it.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Have you trace the power (electricity) through each step? Meaning from the plug connection forward? I do agree to check the Mosfet first. Also make a visual check off all capacitors... Good luck!
의
댓글 달기
i took a heat gun and heated the back of the mother board for 3min and then turn in on the top side heating it for around 4min and it came back on hope yours work
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I was not expecting this to work. I unplugged my Xbox for a couple weeks tried to hook it up today and it didn't work seen this took a hair dryer and went to do that without opening and I am amazed
의
댓글 달기
Jejejeje is very easy i bet u is onley the RF Board the little one behind the faceplate and is onley 15 buks!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Well I have the same problem. Light turns green for about a second then turns back off...I get the beep on the front and that's about it... Also it is not the RF board in the front mister very easy your wrong in this case.....
의
댓글 달기
Had a problem with my 360 slim. Green power dot no rings. Fan going but what caught my eye was the hdd wasn't spinning up. So I found it wasn't (because of a fall perhaps) seated inside properly. Upon opening and taking it out, I switched it on without it in and bingo. It finally worked. Stuck the drive back in and everything was back to normal. Another cause can be a bent usb inner flange in the socket making contact (same symptoms). Good luck. Hope it helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Xbox360 and the xbox360 Slim will display an orange light on the power supply while the Xbox displays red error lights or display a red light on the power supply (a ground fault) while displaying red error lights on the Xbox. This can occur for many different reasons but I'm only going to reference the USB ground fault issue. Forced entry or twisting of any USB cable plug, whether Xbox controller or other proprietary cable or cable connected device may cause a breakage of the USB connector support bridge inside the Xbox USB port. This bridge holds the USB 5.0 volt metal connector and data metal connector and these metal connectors can get bent if there support bridge is damaged or broken. If the bridge is broken then the next time you plug in your controller or other USB device you may push the (metal) 5volt and data connectors towards the rear of the USB port which is like a small metal box. This will cause the 5volt connector on any Xbox or any device to go to ground and cause any type of red light error and may cause either an Amber or Red light on the power supply while the xbox360 has redrings or the xbox360 slim has a red-light. I am not familiar enough with Xbox One errors at this time to make comments about expected errors, although I'm sure a ground fault would occur if 5v goes to ground. To check for this USB ground possibility, grab a flash light and shine it into each of the Xbox's USB ports located on the front and rear of the console. Check for bent and/or broken pins; if found unplug the Xbox & then take a small screw driver or paper clip and pry them apart and/or off the rear of the USB port. Once completed, power back on the Xbox, Done.!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
And what if it isn't this? What if you have these symptoms on an x-box 360 slim that you've double checked several times for ground faults? What's the next item in the decision tree to check?
의
댓글 달기
Mine just makes a sound but nothing goes on. The light on the power supply is orange but I click the power button and nothing turns on just the sound when you click the power button and a sound when you push the open tray button.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mrhyde1018 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 42
전체 시간: 34,566
