주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Blackberry Curve 8530으로도 알려진 RIM RCL21CW는 2009년 8월에 출시되었습니다.
How can fixed charger port micro USB
.Damage Micro USBDamage Micro USB
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@alllo , alllo , Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the BlackBerry Curve 8530 to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board(not your device, but shows how), if confident give it a go. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
BlackBerry Curve 8530 마더보드 교체
https://www.youtube.com/watch?v=rTim6FIJ...
http://www.ebay.com/gds/How-to-Fix-a-Bla...
http://www.ebay.ca/itm/2-pcs-Micro-USB-C...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
alllo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 458
