주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore Elite HE3는 Kenmore의 세탁기입니다. Whirlpool Duet과 동일한 모델입니다.
Loud banging during spin cycle
During the spin cycle there is a loud banging noise. I noticed that the stainless steel inner drum is loose. When I spin the drum by hand, it feels like there is something between the two drums.
Thanks in advance for any help you may be able to provide.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 5개
선택된 해법
Cause 1
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Cause 2
Tub Seal and Bearing Kit
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. If the washer is noisy during the spin cycle or is leaking from the bottom of the tub near the transmission, the tub seal and bearing are likely defective. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing the outer tub and bearing at the same time.
Cause 3
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Well Phil, my washer had the same problem, what worked for me was to just push up or over on the barrel. Then do your wash, after that load is done push up or over on the barrel again. Repeat this process every time you do your wash for at least 2 weeks. If that doesn't solve the problem, stop the washer will it is spinning, push up on it, or over on it. If none of these work, I am sorry I couldn't help you.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Hi, Tania; What in the name of Heaven is meant by "push up or over on the barrel"? Is the barrel the inner tub? And how does one push up or over on a tub that you can only access from the top? Please clarify in the extreme. Thanks!! (Mitch G.)
Agreed what the !&&* does this mean?
Thank you Tania !!!!! You saved me a bundle !!!!! I lifted the drum from the medal rim and moved it up and over to the left..... My machine works PERFECTLY !!!!!!! God Bless You !!!!!!!
Is this this a front loader my is does work on front loaders too. lindadurst22@yahoo.com
댓글 달기
@Oneofhisalso can you please explain in more detail? I’m nit sure what you mean.
Grab the inside bucket with two hands, one one each side, and try to pull up and pull it to the left? Is that what you mean?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
For people looking here for loud banging during the spin cycle but their drums are not acting weird, I just had this problem. It turned out that I had two (of four) shocks that had broken mounts, and the other two were very loose (not much friction when pushing and pulling on them). I replaced all four shocks and it works great now. Got a good deal on Amazon, I hope they last, but if not, at least I know what the problem is now, and may elect to spend more money on shocks at that time, but for now I am happy.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Where are these shocks and how to open and start this process? Great appreciate any help
Here is the page for the shocks I bought on Amazon. There is a video that shows where they are. Mine are still working great!
8182703 Washer Shock Absorber Replacement for Whirlpool, Maytag, Kenmore/Sears, Kitchen Aid Washers 8181646 - PS989596 - AP3868181-4 Pack - 1 Year Warranty https://a.co/d/5y9F2E6
It’s not the shocks . I checked again , it’s the inner aluminum drum that hitting against the outer drum.
댓글 달기
My front loader has this problem . A plastic rim came out and I have broken shards of plastic in the drain pump
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Phil 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 56
전체 시간: 26,113
