주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fingerprint sensor not working water damage
I recently dropped my phone in water and after I dried it off the speakers worked fine and everything seemed perfect accept for when i tried my fingerprint again. I attempted to delete and redo the fingerprints but I had no luck. Any help?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
After a glass of water fell on my phone the fingerprint sensor did not work despite my phone is fine but finger sensor not work , any possible solution ???
Yes I also had the same problem but after I tried everything the fingerprint didn't work or even show in the settings again
댓글 달기
답변 3개
선택된 해법
Unfortunately, the only solution was to get the sensor replaced by a professional which was a bit pricy. But my fingerprint sensor is working just fine now.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I tried everything but eventually put on radiator on a towel overnight and then reinstalled updated security software, switched it off and on and the scanner was back in my settings
댓글 달기
가장 유용한 답변
Did you ever find a solution? Same happened to me.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
댓글 달기
1) You may clean your mobile and then play a high bass song on your mobile
2) then keep your phone work continuesly working for about 2 hours
3) as the processor gets heat up plat the song again to release the hot air inside your mobile then go to sleep with your mobile shut it at power of keep it off all night long and next day delete all your fingerprints then restart your mobile by putting it in flight mode add your finger print it will work I did the same after what happened to my phone
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Same thing happens with my mobile it fall into toilet basin then I bring it out wash with soap and water then keep it on sun...for a day from back side still fingerprint was not working then very next day I kept it on sun for half days from screen side ..then it works perfectly then it use to work on past...
댓글 달기
답변을 추가하세요
Patrick De Castro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 54
전체 시간: 18,656
