주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BLU Life XL은 모델 번호 L050U로 식별할 수 있습니다. 이 스마트폰은 2016년 1월에 출시되었으며, 옥타/쿼드 코어 프로세서, Wi-Fi 기능 및 1300만 화소의 후면 카메라를 탑재하고 있습니다.
data access suddenly stopped working
I actually have a Blue Life XL. About a month ago, data stopped working and I assumed it was a provider issue. Two calls to them led to the conclusion that it's NOT them. All the rest of the family continue on with no data issue on their iPhones. T-Mobile offered little guidance as it is a non-network phone.
Was working fine for several months until non-wifi data suddenly stopped working and I don't know where to start in trying to fix it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
First check the APNs:
https://support.t-mobile.com/docs/DOC-20...
If this is already configured, try a factory reset and configure the APNs again.
NOTE: BACK UP YOUR DATA FIRST!
I would also then try one of the SIM cards that you know works.
If this has failed, there is something wrong with the phone and you should look into a repair or replacement.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Great job to 4k rep! 6k to go.
의 공유
댓글 달기
This was a great help. I checked the settings and they seemed correct, so I went ahead and restored the factory settings and I'm good to go. I feel embarrassed that hadn't tried that already. THANK YOU!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Neil Grepke 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 370
