주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple TV는 Apple이 설계하여 2007년 3월 21일에 출시한 디지털 미디어 수신기입니다.
Why have they all started jumping?
I have 3 Apple TV 1st generations and they have all developed exactly the same fault at the same time. Coincidence? They no longer play saved content (films) without constant pausing and. Jumping. Has anyone else experienced this issue and - if so - what's the fix? I have tried a factory restore on one, but no ch age.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Are you connecting to the same TV? Are these devices hacked (like Kodi or jailbroken)?
Hi, they are attached to different TVs (the same ones that they have each been attached to for ages) and have not been hacked.
댓글 달기
답변 1개
선택된 해법
Check your local connection (Ethernet or WiFi) internet connection if you are streaming as that maybe the real issue.
If you live in a dense area its likely someone is stepping on your WiFi band if you are using WiFi to connect the Apple TV to your Internet Router. If you are using wired Ethernet connection then it could be an ISP issue.
If you have a Mac give this app a try: WiFi Explorer it will allow you to see the bands that you and the others around you are using.
이 답변이 도움이 되었나요?
점수 2
댓글 14개:
Thanks,but would that affect the playing of movies saved onto the Apple TV 1st generations own hard drive?
No, But to be sure I would disconnect the network connection (Ethernet or WiFi) as their maybe some other process running in background which is having an issue.
I also need help for this
Same as what @ispl said
"playing videos on the apple tv hard drive"
Please help
@beanman56 - The drive maybe failing or highly fragmented so the movie is to badly scattered across the platters.
Ok thanks for the help,
Also @danj do know what format it takes for external drives?
댓글 9개 더보기
댓글 달기
답변을 추가하세요
pipbaldwin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 12
전체 시간: 644
