주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 3월에 처음 출시된 3세대 HTC One 스마트폰입니다. M8 디자인에서 크게 개선된 점으로는 옥타코어 Snapdragon 810 프로세서와 2000만 화소 후면 카메라가 있습니다.
HTC One M9 G-Sensor problem, a solution?
Hi, I have a HTC one M9, few days ago the smartphone fell to the ground and since then the G-Sensor doesn't work. I have done the calibration using HTC code( *#*#3424#*#* ) but nothing!
I think it is a hardware problem, is there a solution?
Thanks for your time!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
There possibly is! Exactly the same thing happened to me and I thought it was time for a new phone. I assume you've tried to calibrate your sensors (go to 'help' - 'troubleshooting' - 'Display and buttons' - 'The display doesn't rotate automatically' - 'G-Sensor', then test and 'calibrate G-Sensor'). Apparently if you do this several times this can fix the issue, but it didn't fix mine. I then came upon the 'drop fix'. If you've dropped your phone, as I did mine, it can put the sensor out. So you use the same method to put the sensor back in again! Hold the phone about 6 inches above a thin carpet or pad of paper and drop it onto each corner in turn. Then drop it flat on its back and again on its front. Hey presto, mine started working again. Hope this helps!
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
Thanks, mine started working again too!
의 공유
Really glad to hear it, An. There's nothing worse than that sinking feeling of thinking you've broken your phone!
의 공유
Awesome! It really worked. Thank you.
의 공유
Glad to hear it Marco. Stay safe!
의 공유
Brilliant! Another phone saved, another user comforted in the dread of having broken their phone! Thank you so much.
의 공유
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Valerio Tregatti 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 1,478
