주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년에 출시된 ASUS Eee PC 1001PX 시리즈에 대한 수리 안내서 및 제품 사양. 이 노트북 시리즈는 10.1인치 디스플레이와 Intel Atom N450 프로세서를 탑재했습니다.
How to repair touchpad flat cable?
ASUS Eee PC 1001PX 하드 드라이브 교체
Hi guys, firstly I would like to thank who did that guide. It's wonderful. Unfortunately, I didn't find that one before trying it. So, I damaged that flat cable that connects the touchpad on motherboard. The link below is the picture of the damaged cable.
이미지
What could I do to repair the damage? If the solution is purchase another cable, what's it?
Many thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Hi Steffen,
Thank you for the answer, but to buy it by the eBay for who lives in Brazil is more difficult and the sellers don't put more specific data about.
Recently, I took a common ruler and measured the cable width. The picture shows it:
[image|1221870]
I knew it has 12-pin, but I need to find the pitch measuring because on the internet (Aliexpress website) I found more than one pitch measuring, but I think it would be 0.5mm, don't you?
Best regards
댓글 달기
답변 1개
가장 유용한 답변
Hi Diego,
I recently uploaded my repair guide on how to replace the DC jack power (charging socket) on an ASUS 1001PX which also includes the removal of the upper unit/touch pad. You will find it here: ASUS Eee PC 1001PX 충전 소켓 교체
What is actually needed in your case is a 12 pin flat ribbon cable which you easily find online, for example:
http://www.ebay.com/itm/Asus-EEE-PC-1001...
https://www.ebay.com/sch/i.html?_from=R4...
For sure, you can also buy the entire touch pad unit, for example, here: https://www.ebay.com/sch/i.html?_from=R4...
However, if you only need the flat ribbon cable, I suggest that you buy a single ribbon cable that is as long as your old one is and just fold it the way you need it. This should do the job!
Steffen
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Diego 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 4,012
