Why is my disc player won't open?
During my Xbox is power ON, pressing button and joystick Disc Player button to open tray...it won't open..what can i do to fix it without costing me more money...??..thank you
좋은 질문 입니까?
좋은 질문 입니까?
MS has a tutorial for getting the tray open manually: http://support.xbox.com/en-US/xbox-360/c...
해당 답변은 도움이 되었습니까?
That is one solution; but if the drive still will not open, it will most likely need to be replaced.
There may a game disk or DVD lodged in the player. My suggestion is to first investigate and attempt all manual options to open or fix the player prior to replacing it. If all options fail, then replacement may be your only option. Here is some helpful information:
There is an emergency eject button that can be found directly under the Xbox 360 logo, but the faceplate must first be removed. See Microsoft's Directions to Manually Eject the Disk Tray.
For another useful link, see iFixit's How to Remove a Stuck Game from an Xbox 360. Either of these links should be most helpful.
If that does not work, this iFixit link to repair the Optical Drive should work. See Repairing Xbox 360 Stuck Optical Drive.
Lastly, when all solutions above have failed, you may most likely need to replace the Optical Drive. It is a bit difficult, but not impossible to do. See iFixit's Xbox 360 Optical Drive Replacement.
안내서
난이도:
쉬움
5 minutes
안내서
난이도:
어려움
안내서
난이도:
운영
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 602
