주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 노트북은 2010년 9월에 출시되었으며, 모델 번호 Inspiron N5030 또는 Inspiron 15로 식별됩니다. 전체가 검은색인 노트북으로, 윗면 덮개 중앙에 DELL 로고가 있고 마우스 패드에는 좌우 버튼이 분리되어 있으며 노트북 오른쪽에 디스크 드라이브가 있습니다.
compatability of ram and cpu
I have a dell inspiron 15 N5030 with a Pentium T4500 dual core cpu and just bought 2x 4GB DDR3 1333 (CP3-10600) SODIMM chips for upgrading....I want to upgrade the cpu to the Pentium T9500 core duo cpu and want to know if it will support the same ram chips I bought? thank you very much for your time.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Stephen -
According to Dell support site (http://downloads.dell.com/Manuals/all-pr...) Page 75, the N5030 will support up to 4GB of DDR3-1333, so you should be Ok.
Russ
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
He has 8 Gb of ram that he got. So he wont be ok.
의 공유
Ooops! Thanks.
의 공유
A lot of time, they only test out to 4GB but, I have put in twice that amount and had it work with no problem. It will probably be fine.
의 공유
댓글 달기
Russ above said that it supports 4gb but i find that its very possible that it can support 8gb.
Give it a shot. As long as you have a 64 bit version of windows, you should see all 8gb. It wont hurt anything if you do not.
Hope this helps! If it did please hit the accept answer button!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
thank you everybody for your input....yes I have a current 64 bit windows system....I am currently waiting for that 8GB worth of DDR3 1333 CP3-10600 chips cause I found out the stock t4500 is a 1333 system...am I right in assuming the stronger 9500 would support the same amount? and is it a 1333 cpu also? or more...I can't find the specs anywhere
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Instead of upgrading the CPU, you would get a better speed kick if you upgraded the hard drive to an SSD.
의 공유
I know ssd drive is way faster than my current hard drive in my dell inspiron 15 N5030 that is running at speed of 5400rpm...I want to know if installing an hdd drive at 7200 will increase my speed more than upgrading the stock t4500 cpu to t9500 at an increase of 2.3ghz to 2.6?
one other factor you should know is that I have the ram maxed at 8gb dual channel and is running at a speed of 6-6-6-15 clocks/latency which I've been told is faster than the chips were designed for
의 공유
Hello Stephen,
Have you got success with upgrading CPU and RAM memory?
의 공유
댓글 달기
답변을 추가하세요
Stephen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 21
전체 시간: 2,431
