Wont idle when warm
Truck has a 22r. it runs fine until warm then it wont idle.
좋은 질문입니까?
@lvec1 , Lou Vecchia, Possibly a stuck EGR valve or vacuum leak, although there are a lot of things that could cause idle problems, dirty carb., weak fuel pump, clogged filter, bad plugs, failing coil, etc. etc.. Links below may help trouble shoot your issue.
이 답변이 도움이 되었나요?
Ok Thanks. ill check the links.Going to work on it on Thursday.Ill post what i found. I have replaced the carb and checked for vacuum leaks.
my 2003 toyota truck will run but will not idle and dies
이 답변이 도움이 되었나요?
new gas tank and fuel pump and new idle senor. new fuel filter
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 2,121
