forgot my pin number
how can I bypass lost pin number
Update (05/10/2017)
I have a Samsung galaxy note 3 model number is sm-t210 can I get in without loosing everything by doing a factory reset ????
좋은 질문입니까?
좋은 질문입니까?
https://android.gadgethacks.com/how-to/7...
There are a few different ways that do not involve data loss.
I hope this helps! If it did please hit accept answer!
이 답변이 도움이 되었나요?
The only way to bypass the unlock code is to factory reset your tablet, you will loose all your data though.
1. Power off your device.
2. Boot in recovery mode by pressing and holding Volume Up, Power Button and Home Button at the same time.
3. Release all buttons when the Samsung Galaxy Tab 3 Lite 7.0 screen flickers and in a few seconds the Recovery screen will appear.
A menu will appear use the volume up/down buttons to navigate to Factory Reset option and press the power button to accept, select OK/YES from the menu the proceeds to Factory Reset your tablet
이 답변이 도움이 되었나요?
yes its very helpful for me
I cannot switch the tablet off without the pin number?
Not helpful because it doesn't work on every tablet I did all this and the pin is still there
It says draw of directions to unlock screen
이 답변이 도움이 되었나요?
What I want to do is to unlock my Samsung Galaxy Tab
The tap says draw series of directions to unlock screen
More than a year now
이 답변이 도움이 되었나요?
What does score 0 mean?
Am failing to understand score 0
Hey Luke you need to do a hard reset this may not work but try power off then push volume up and power button for about 4 sec. if it trys to power back on go 3 sec. what you want to do is get the robot on there and volume buttons up and down will guide you to reset enter will be power button good luck
이 답변이 도움이 되었나요?
Somebody gave this tablet the The Samsung Galaxy tablet 3 but the person does not remember the PIN number so how can I get in it to break the PIN number so I can open up the tablet
이 답변이 도움이 되었나요?
How can I get into Samsung Galaxy tablet 3 when the person that gave it to my son doesn't remember the pin number which is a four number code how can I get into it to open it up and it won't allow me to do nothing
지난 24시간: 2
지난 7일: 9
지난 30일: 20
전체 시간: 48,252
댓글 11개
Look at what i posted. I have multiple options on how to do it.
Cameron 의
How to unlock a pin code from screen
abelsruth01 의
i forgot my 4 digit pin to my samsung galaxy tab how can i know what is the password
Christina Augustine 의
How can I unlock my Samsung Galaxy tablet for my pin number
Kenneth Mitchell 의
I forgot my 4-Digit pin to my Galaxy tablet how can I recover that without hard booting it and losing all my information
angelg1568 의
댓글 6개 더보기
