주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer Blade Stealth는 Razer의 프리미엄 울트라북 라인입니다. 최신 모델은 Razer Blade Stealth (2019)입니다.
My battery stopped working?
for a long time now my battery life persentage in windows has been going between working and not randomly but starting four days ago my laptop wouldn't start when nott in charger and when i finally checked the battery pannel in the task bar it said that there was "No Battery Present"
so my question is: How do I fix this? Do I have to open it up and reinstall the battery? or do i have to send it back to Razer?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
선택된 해법
If the laptop is under warranty return it but if its not then open the laptop follow this video You can find replacement batteries on ebay or amazon. Depending on your model. Hope this helps
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
Send it back to Razer. If you open it it will probably void the warranty. They will most likely replace it.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Send it back to Razer .........for a battery replacement ???
Why not just scrap it and buy a laptop that you can buy a battery for without paying the shipping as it appears Razer support is lacking in more ways than I could possibly mention here. Razer doesn't sell parts but they don't mention that and they don't mention how bad their support is which brings me to wonder how bad does it have to get before somebody, somewhere thinks its worth mentioning. No more Razer laptops are being considered in my future, Stick with MSI, Lenovo or any brand that you can buy a battery without paying shipping and whatever they charge to replace a battery, I can't get over how bad this is as "They will most likely replace it" doesn't provide much in the way of assurances or conviction.
의
@R Hebner There's no way to sugarcoat it, their support is garbage. I just suggested what I think would be most economical.
의
댓글 달기
most of the time the battery not detected issue will be caused by a thermal resistor or thermal fuse inside the battery pcb itself, in other words a bad battery. However, sometimes it comes down to a motehrboard issue such as a clock or data line to the battery being corrupt. Feel free to send it in if you would like a free diagnoses of it. I'd be more than happy to help with this repair.
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
@techworksrepair careful with offering your services but not actually providing an answer to the question. Like "to a motehrboard issue such as a clock or data line to the battery being corrupt." which one and how do you test for it?
I would not want you to get called out on spamming
의
So you dont think i provided an answer to the question? I certainly did just explain what it most likely is. I know this because i repair hundreds of these devices and a clock/data line for battery is whats responsible for detecting of the battery, current sensing issues would be more of a not charging issue. I can tell you what to check, in this case the pcb of the battery for open thermal resistors and fuses, which you have very easy access to on these models because the battery is held together with tape, or the many different data lines going from the charge controller to battery connector or to the IO. I can't possibly tell you which one it is out of all of them, I'm not a wizard. Most likely if someone does not know how to use a multimeter to go about checking these issues, then they also most likley do not have smd soldering equipment, and are therefore most likely not going to repair it themselves. If they do have equipment though, I'm always happy to help in diagnosing it over the internet!
의
Thanks for the answer, it helped me a lot, Brenden
의
I have one more question: if the problem is intermittent. Do you think it is the battery itself or the mobo? Would a reformat help?
Thanks!
의
If it is intermittent issue, of battery not detected, from what I see, it is more commonly the battery itself than a line on the motherboard.
의
댓글 1개 더보기
댓글 달기
hey @techworksrepair how can i contact you? my name is andres and i have a razor blade 15 base model and where the battery goes in does not fit and i think is broke
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
shane taylor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 27
전체 시간: 13,214
