주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
49cc 가스 구동 스쿠터에 대한 안내서 및 수리 정보입니다.
No start on electric starter
My scooter starts fine with kick starter but has no spark when I try to use electric starter.
It has new battery and ignition coil and plug.
Turns over fine just won't catch
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개:
@lawless sounds like a wiring issue. What make and model is your scooter?
My scooter is a hover one eagle and so when I got it and it didn't turn on I started troubleshooting when I opened up the display unit in the neck I found that there was a set of wires not connected it has a black connector and there's five wires to it there is nowhere that I have found in the neck or the display unit that these wires hooked to
댓글 달기
답변 3개
I have a Yamaha tweet 50cc kick start works but not electric starter l have new battery new starter botton n spark plug what else can it be
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check for spark at your spark plug. Replace after testing the CDI. (Capacitor Discharge Ignition) Replace coil wire. Check the starter relay with a voltmeter. Next check the voltage regulator. The last worst-case test is your Stator. Can also be your timing is off. I just performed all these steps except replacing the Stator but that tested alright with the meter. I still think 1 of the New ignition wires is grounding out my kill switch, ran fine until I replaced the New Ignition Module Assembly because I lost my keys. I will post when I resolve Which Wire is the Problem.! P.S. Electric start working fine now after changing some wires around on the ignition( New 1 has 5 wires and only 4 connect. The kickstart will not start it though, barely turns the engine.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It's an electric kick scooter guys sorry
댓글 달기
Comment réglage carburateur
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Phil 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 64
전체 시간: 2,891
