주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 YD201로 식별되는 Yotaphone 2는 러시아 Yota Devices의 두 번째 제품으로, 전면 AMOLED 화면과 후면 전자잉크 화면을 탑재했습니다.
How to replace the battery?
I have Yotophone purchased in UAE and the battery after charging drains out. How can I change the battery? appreciate receiving your reply per return.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
How fast does it drain? When did you get the phone?
의 공유
댓글 달기
답변 4개
선택된 해법
hello_chandran, You may want to check the 1st and 2nd link below for concerns on battery draining before changing the battery. 3rd link, below is a disassembly video link that will show how to get inside Yota to enable changing of the battery. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://howtodothing.net/yotaphone-2-batt...
http://www.gearbest.com/blog/how-to/easy...
https://www.youtube.com/watch?v=_Kr1dnav...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Its easy.
Just need to remove the cover where the usb port is. Its easy , just glue , Remove the screws and with plastic tool remove the screen from edges. its easy, aa lot of videos in youtube. Dont worry, its not hard.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
you are right, it's even much easier than shown in the videos
1) you need to remove the plastic cover off the usb port
2) lift off the back screen
3) unplug the 2 sockets of the back screen and remove the back screen
4) unplug the battery socket and remove the battery, which is glued, take care, gently
5) plug the socket of new battery and glue it by gently pushing it into its space
6) reinstall the back scren and the plasti usb cover
It was the first time i did something in a smartphone and it went smoothly all right
의 공유
댓글 달기
Take a look into a Yotaphone's disassembly guide HERE
이 답변이 도움이 되었나요?
점수 0
댓글 달기
where can we buy a good quality original battery for YotaPhone 2?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
hello_chandran 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 41
전체 시간: 4,852
