주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Turtle Beach의 Stealth 500P에 대한 수리 정보입니다. Stealth 500P는 PS3 및 PS4 게임기에 최적화된 무선 게이밍 헤드셋입니다.
Volume knob stuck at highest setting
My stepdad bought me the Turtle Beach Ear Force Stealth 500P headset two years ago and recently the volume control stopped working. Currently it's stuck at the highest setting. So, when I play some games that does not have their own volume control it's super loud to the point where I can't play it with my headset without causing my ears to explode. Anyone else have this issue and possibly a fix? Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 7개
I'm having the same problem. They were working fine and then suddenly the volume just turned up really loud and won't go down
의
Yeah, I have the same issue as well. I don't think anyone has the solution to this problem.
의
im having the sam issue with the stealth 400's im thinking either the scroll peices for the headphones are internally stripped or a solder broke.. =/ wont know for sure until I take them apart lol
의
Same issue here. I think i have had success putting side pressure on the roller when i adjust it but is is inconsistent. Any luck figuring out the cause? before i take mine apart also.
의
I have the same issue, about to ditch turtle beach since it’s a known issue and they won’t do anything about it.
의
댓글 2개 더보기
댓글 달기
답변 4개
가장 유용한 답변
You're definitely not alone.
As mentioned in a comment in the link above, try power cycling them.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
이미지
이미지
이미지
이미지
Here is the part I was able to get out. Where can I find the replacement
이 답변이 도움이 되었나요?
점수 1
댓글 7개:
ok, I have ended up removing the POT.
I am using the 400xp stealth in a PC application and before I had a full volume only. very hard to control with the pc volume control
with the pot removed, I can control the headsetbetter with the pc system volum controller
의
just figured out.
If I set the device up as Realtek digital audio device on PC and not select the Stealth, then my PC can control the sound without any issue. I which I tried that before I took off the pot.
의
Coxwain can you please explain what you did to fix the issue? Nothing happens when I switch to realtek and lower the volume. Still stuck on highest volume
의
댓글 2개 더보기
댓글 달기
I have this issue with my 420x and after some research the only fix i could find would be to replace the volume potentiometer but that requires taking the headset apart and soldering a new one in, no problem for me, but where does one find the super slim potentiometers used in these headsets?
이 답변이 도움이 되었나요?
점수 0
댓글 9개:
Take the potentiometer out, get the part number off from it, eBay the part number... Solved. Solder new one on when it arrives.
의
I have takent the part off the TB stealth 500p, here are the markings
CT1508
B104
now I have to try to find the potentionmeter to replace it
의
I think its a 16mm x2mm dial
의
I haven't had much luck. I finally got the 16x2 B104 which are 100k resistor potentionmeters and the sound is too faint.
not sure if there is another issue or not but I think I will abandon this project.
의
BTW I have extra potentiometers 16x2mm T104 if anyone wants a couple. I had to buy in bulk. Just pay a couple$ for shipping
의
댓글 4개 더보기
댓글 달기
Mine has the knob where you change chat volume stuck in the mic itself so I can't move it do you know how to fix that?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Loyd Latture 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 38
전체 시간: 17,922
