주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mercedes W115 수리 안내서는 1968년부터 1976년까지 생산된 200/200D, 220/220D, 230.4/230.6/240D, 250, 280, 300D와 그 외 다양한 왜건, 쿠페, 세단 등 W114/W115 모델을 모두 다룹니다.
replacing driver side check strap
I need to replace the door check strap in my 76 300d W115. Took door panel off, but you can't get the check strap out without taking the entire window assembly out, it appears to me.
am I missing something on replaceing, and what is the proper procedure to removing the window etc.
need some advice on this.
thanks
Philip
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@yadkin2002, Philip, I do not believe/not positive the entire window should have to come out to change the door strap, you should have to remove the pin and bolts and may have to turn(manipulate) the old strap to remove from door cavity or possibly have to loosen front window guide/track. Just to add a little to OT post, the video links(not your exact model) but may help in the removal of check strap. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=m3_NggBa...
https://www.youtube.com/watch?v=R0U3VNbb...
https://mercedessource.com/store/mercede...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Philip 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 644
