주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
20 질문 전체 보기
PowerBook G4 will not fully power on or boot
Hi I have searched for the most specific answers and tried many of the suggested solutions. None have worked as of yet. I'm hoping to narrow down what the next step is going to be. Here is what's going on:
  1. Battery does not charge, one flashsing green pip only
  2. Power at DC in glows constant green, no change when turned or wiggled.
  3. Will not fully power on with battery in
  4. Will not fully power with DC only and no battery
  5. CapsLock will light, but computer does not boot.
  6. Ctrl/Alt/Shift/Power process does nothing
  7. Swapped RAM no effect
  8. Tried one RAM card only in each slot, no effect
Thanks in advance.
Powerbook G4 17" 1.3GHz Approximately 2001 or 2002 Serial V73483UWP22
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Model ID is A1052
birdinlay
PowerBook G4 1.33 17" (Al) 1.33 GHz PowerPC 7447 (G4)
Intro. September 16, 2003 Disc. April 19, 2004
Order M9110LL/A Model A1052 (EMC None)
Family 17-Inch 1.33 GHz ID PowerBook5,3
RAM 512 MB VRAM 64 MB
Storage 80 GB HDD Optical 2X "SuperDrive"
댓글 달기
답변 2개
Replace the battery. The 100% charge level of this one is kaput.
UPDATE 5/30/17
I have found this supplier to be very good with selling reliable 3rd party batteries and shipping time has been excellent:
http://www.ebay.com/usr/shop-siker?_trks...
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Thanks, shouldn't the powerbook boot up without the battery though? Battery may be kaput, but seems like something else may also be going on. Thanks again!
Seem like as it gets older, machines need more juice to boot. Some won't boot at all without a battery.
Fair enough. Anyone know a reputable battery seller that won't cost $200? Thanks for the responses
Check Amazon reviews. There are no more genuine ones in production, only 3rd party batteries.
댓글 달기
가장 유용한 답변
birdinlay, besides the answer from @mayer try following the Apple troubleshooting steps:
Startup
The computer will not power on (no fan movement, hard drive spin up and display is not lit)
1. Remove any connected peripherals and eject any PC card.
2. Check that the battery has enough charge to start the computer by pressing the button next to the LEDs on the battery. At least one LED must light solid (not flashing).
3. Connect a known-good Apple 65W Portable Power Adapter and power cord or plug to a known-good power outlet; make sure the DC plug is firmly inserted. The DC plug should light up, if not, replace DC-in board.
Important: The Apple 65W Portable Power Adapter is highly recommended to be used with the PowerBook G4 17-inch series computers. The adapters can be identified by 65W in the name and markings, and the metal securing-stud on the plug connector. Although previous 45W power adapters (see Knowledge Base article 88231 PowerBook and iBook: Apple Power Adapter) are plug compatible with the
PowerBook G4 17-inch series, it may not provide sufficient power during some activities and power may be drawn temporarily from the battery.
4. Try powering up without the battery installed (only works with 65W power adapter).
5. Reset the power manager. See procedures under the “Resetting the Power Manager Unit (PMU)” heading in the Hardware Troubleshooting Tools and Tips section. Warning: Resetting the power manager will permanently remove a RAM disk, if present, and all of its contents. You will also need to reset the date and time (using the Date & Time system preference pane).
6. For PowerBook G4 (17-inch Double-Layer SD) only, boot up the system and check the sleep indicator. If it turns on solid and turns off, the main logic board is getting power and completing the boot cycle. If no video appears, there is an issue turning the video on or system software is corrupted. Try booting off the DVD. If the light does not turn off, the boot cycle is not being complete. This may be cause by the hard drive not being seen by the system, system software corrupted or possibly a hardware issue.
7. Press Caps Lock key to see if key light comes on. If it does, hold power button down for six seconds to shut down the computer and restart.
8. If it still doesn’t start, verify power button cable is connected properly to top case flex cable assembly and that the flex cable is connected correctly to the logic board, if power button is not functioning correctly or damaged, replace the top case.
9. Disconnect keyboard completely. Inspect connectors. Restart with keyboard disconnected.
10. Remove any additional RAM.
Hardware Symptom Charts PowerBook G4 (17-inch DLSD/1.67/1.5/1.33GHz) Troubleshooting - 19
11. Try disconnecting the AirPort Extreme flex connector from the logic board and start the computer. If it starts, shut it down and check the flex cable connector and the connector on the logic board and replace the damaged parts.
12. Reseat these flex cables:
• DC-in flex cable
• Hard drive flex cable (will boot to flashing folder)
• Optical drive flex cable
• PC card cage flex cable
• Keyboard flex cable (on PowerBook G4 (17-inch 1.67GHz) only)
• Trackpad flex cable
• Right USB flex cable
• Modem flex cable
If the computer starts up, inspect the flex cable connector and its connector on the logic board for damage and replace the damaged parts.
13. Remove AirPort Extreme Card.
14. Try known-good DC-in board.
15. Replace logic board.
Let us know what you find out.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thanks, if found most of these steps, but some I hadn't. I'll give this a go down the list and let you know what happens. Thanks again!
You are welcome and hope it works out.
댓글 달기
답변을 추가하세요
birdinlay 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 1,936
