주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
iPhone 4s black out and broken power button
My iPhone's glass screens(on both sides) are very cracked. There are also open gaps on each top corner of the front screen about 1 square cm each(I'm very careful about anything getting in there and I plan to replace the screen). I've also been using assistive touch for the past 2 weeks because the power button doesn't work(it seems stuck/jammed). And lately, it's been shutting off and I can't turn it back on unless I plug it into the charger. But today it turned off and didn't turn back on when it was plugged in. The odd thing was that Siri worked, but it was still blacked out.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
These are the parts you will need:
Rear Panel, Front panel (display assembly) and either a replacement power button and sensor cable assembly OR if you have fine tweezers / razor blade you can replace this part on the power button instead:
http://www.ebay.com.au/itm/10-X-Power-Vo...
Okay so what you will want to do is first disassemble the phone to where you get at least the back cover, logic board and front display assembly out.
Guides to replace parts:
Rear Panel Replacement: iPhone 4S Rear Panel Replacement
Display assembly replacement: iPhone 4S Screen Replacement
Power and sensor cable replacement: iPhone 4S Power and Sensor Cable Replacement
If you want to buy the parts from iFixit:
Rear Panel Replacement: iPhone 4S Blank Rear Glass Panel
Display assembly: iPhone 4S Screen
Below is very lengthy, please bear in mind:
If you do choose to buy the small yellow sticker with the button on it to fix the power button (personally I find it easier to do than replace the whole part which takes longer) you will need to use something like fine tweezers, razor blade or exacto knife works too.
Basically what you do is get the phone disassembled to where the front screen is removed. Then remove the two screws that secure the lock button under it.
Then loosen the power button assembly and carefully remove the yellow sticker on the home button mechanism itself.
Take note that there are like two metal pressure plates, one will stick on the yellow sticker itself and the other will fall right off and be hard to find if you don't take note of it.
The one that is loose you will want to keep. Once you have removed the yellow sticker from the metal plate take the other yellow sticker from the other replacement home button. Make sure to place the loose metal pressure plate onto the power button first then put the replacement yellow tape with the metal pressure plate stuck onto there.
If it is done correctly you should have placed the metal pressure plate on the power button then the yellow tape replacement power button on top and made sure it is secured on by pushing it down carefully on the yellow tape around the power button pressure plate with fine tweezers.
After you done all that simply replace the power button back to where it was secured, don't forget the large metal physical button to align back in place too before putting the two screws back in. And it should click again after that.
It's a common issue on iPhone 4 and 4s series phones where the small circle plastic part above the power button gets worn out over time.
Then you are ready to install a new front screen and rear panel after that. It's best not to repair power button when a screen is installed as you can risk bending and damaging the screen cables.
iPhone 4S Screen 이미지
상품
iPhone 4S Screen
$34.99
iPhone 4S Blank Rear Glass Panel 이미지
상품
$19.99
iPhone 4S Rear Panel 이미지
안내서
난이도:
쉬움
5 - 10 minutes
안내서
난이도:
어려움
1 - 2 hours
iPhone 4S Power and Sensor Cable 이미지
안내서
난이도:
어려움
2 - 3 hours
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you so much!! This is very helpful.
댓글 달기
귀하의 답변을 추가하세요
Arielle Marin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 204
