주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 Firestrike Elite 블래스터는 2013년에 출시되었습니다. 플런저 작동식 발사 장치 외에도 레이저 조준 기능을 갖추고 있습니다. 이 블래스터는 원래 파란색, 흰색, 회색, 주황색으로 출시되었으나, 주황색, 흰색, 회색으로 구성된 두 번째 색상 조합도 있습니다.
Back screw will not budge
So I'm attempting to mod my first ever Nerf Gun. I decided to go with something relatively cheap; the Firestrike Elite.
However, before even getting to the inside of the gun, I've encountered a problem. The screw located under the top rails to the back will not move. I've successfully taken out all other screws, but this one will not budge. My screwdriver simply glances over the bumps of the screw, and I can never get a good hold on it. I managed to move it about a quarter rotation once, but that's it.
Can someone please give me some tips?
Thank you,
JR
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@dkinger, JR, Hopefully the screw head is not stripped. Try heating up the area with a heat gun/hair dryer right where the screw is threaded in, get it hot to the touch then try removing the screw. This should expand the area of the screw a little to allow for removal hopefully. The only other thing may to use a drill and small metal bit(a wee bit larger then O.D. of threaded portion of screw) and drill the head off screw and then disassemble and use small vise grips/pliers to turn out remaining screw shaft. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Justus Rodriguez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 22
전체 시간: 1,101
