주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.4GHz 또는 1.6GHz 프로세서, 64GB 또는 128GB SSD.
User upgradable RAM for 11 Inch MacBook Air
Can I upgrade my 2 GB of RAM on my new (late 2010) 11 inch MacBook Air?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 5개
가장 유용한 답변
Hi, According to the included link the ram on your machine can only be upgraded at time of purchase. Sorry.
http://www.everymac.com/systems/apple/ma...
이 답변이 도움이 되었나요?
점수 4
댓글 달기
The SSD is secured by a T5 Torx screw. Do NOT try to unscrew it with a T6 or you will thread it. I almost did that since I read somewhere you need a T6 Torx screwdriver and this is INCORRECT. I bought a T5 since it wasn't in my toolkit and that is indeed the correct one. T5. Make note of this.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
It looks like they say SSD is not changeable but in reality it is. Maybe the same thing works with ram?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The ram is soldered to the motherboard. When you remove the SSD, which is secured with a t6 torx screw you can clearly see the memory modules. The modules are spread out on the actual logic board rather than a removable memory module.
The 2011 model moves the memory to a new location however it is still soldered directly to the logic board and is not removable.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
yes you can easy
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
rickdesigndad 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 19
전체 시간: 19,939
