주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
Logic Board Swapping to Access Memory
Hello,
The case is my IPhone 4S has many broken parts, the screen broke, home button not functioning, battery died and charging port is probably broken.
I am trying to recover my data but the phone won't turn on, but I know it's still working because last month I was able to access it briefly (while it's broken like that).
Would it be possible to switch the logic board to access the phone?
And I mean that, can I take the logic board from the broken phone and place it in a new phone (of the same type) and gain my data from it that way?
or should I try replacing all the broken parts?
Any advice is appreciated and thank you in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Yes, you can swap the board into a different phone and "should" work based on what you are describing. It would be cheaper to perform a repair on that device. You can buy a battery, screen and charging port for pretty cheap.
iPhone 4S 배터리 교체하기
iPhone 4S Screen Replacement
iPhone 4S Dock Connector Replacement
You could also look around for a whole phone that you could simply out the old board into if you can find one cheaper then that parts are.
Start with a battery if you don't want to buy all the parts to confirm it'll turn on with a new battery.
iPhone 4S 배터리 이미지
안내서
iPhone 4S 배터리 교체하기
난이도:
조정
10 - 30 minutes
iPhone 4S Screen 이미지
안내서
난이도:
어려움
1 - 2 hours
iPhone 4S Dock Connector 이미지
안내서
난이도:
조정
25 minutes - 1 hour
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Basing on where I live, it would be easier to buy a phone and replace the inside.
Thank you for the response.
댓글 달기
답변을 추가하세요
Kylar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 433
