주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
쉐보레 Aveo의 1세대 모델로, 내부 코드명은 T200이며 T250은 페이스리프트 모델입니다. 이 차량은 Pontiac G3, Daewoo Kalos 또는 Pontiac Wave라는 이름으로도 판매되었습니다.
How to replace the AC condenser?
I went ahead and refilled the freeze on gas on the low pressure end of the vehicle refill pipe. A man told me to relieve the pressure from the high pressure end and continued to fill with freeze on on the low pressure end. The condenser turns on but no cold air comes out.
How do I change the condenser in this vehicle since it does not seem to be working ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@jason5887, Jason, I take it you mean AC compressor. I will post proper charging procedure in a link below. Before changing anything your problem could be a leak in the AC system/bad relay/fuse/plug/wire/switch/etc. and should be checked for this, trouble shooting/repair links below may help solve your AC's issue.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.aa1car.com/library/ac98.htm
https://www.youtube.com/watch?v=pCv7rCdc...
https://www.youtube.com/watch?v=_Peb9o-L...
https://www.youtube.com/watch?v=Pdq8JAlc...
https://www.youtube.com/watch?v=w17DpGCc...
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you so much I will go though these trouble shooting procedures and hopefully these solve the issue regarding the compressor.
의 공유
댓글 달기
답변을 추가하세요
Jason Mendez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 3,316
