주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple AirPods는 2016년 12월에 출시된 무선 헤드폰입니다.
Has anyone ever received this error?
Has anyone ever received the error for the AirPods with a ! near the left or right pod? Right pod won't work at all.
Update (06/05/2017)
이미지
Thank you
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
I had a problem with a non-fucntioning right Airpod. It did not show the alert above, it just didn't connect or appear in the Battery widget on my iPhone.
I noticed that replacing the Airpod in its case did not trigger the charging light, so I deduced that the case didn't recognize the Airpod was there. That gave me a possible cause: the metal charging contacts were not touching the airpod when inserted, so the airpod had run out of battery, and the case wasn't charging it.
I was able to bend the contact back into shape with a paper clip (not easy due to the shape of the cae & the strong magnets) but when I was done, the Airpod quicky charged and worked as normal again.
As of this writing, Apple's online support was not able ot figure this out & only offered a replacement right airpod.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Who, good comment. This is happening to me. Any advise about how to do it?....
의
Be advised, you may void your warranty. But if you can pull the contacts in the case closer together, you’ll have a better chance getting the non-charging AirPod to charge. I used a very small screwdriver to pull on the contact, making a tighter fit around the Airpod
의
댓글 달기
I have heard of this problem before and also of a solution that works for some. Disconnect the Air pods then press and hold the Bluetooth setup button on the back of the case until the status light flashes amber a few times and then finally flashes white. Make sure it flashes amber before you release the button. After doing so reconnect the Air pods and the problem should be resolved.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I did this and it did not work. Thank you for responding.
의
Check to see if they are under warranty, it may be a faulty set. Stop in at a local apple store if there is one around and they could possibly just replace the set.
의
댓글 달기
답변을 추가하세요
Andrea Baraba 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 27
전체 시간: 1,286
