주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RCA 10 Viking Pro 기기 및 수리 안내서입니다. 모델 번호 RCT6303W87 DK로 식별할 수 있는 분리형 키보드가 포함된 안드로이드 태블릿입니다.
I have a cracked screen
I have read good information on replacing a screen. However, where do I get a new replacement screen? Also, are there people available to replace it for me?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 2개
@sharonpink if you can give us your tablets model number, I am sure we can find the right screen,
의
RCT6K03W13H1 I think that is the model number. Please realize you are dealing with a non-techy great grandma who wants to learn how to use this devise for more than playing Scrabble. If this can be fixed, I will look for a manual so I can learn.
의
댓글 달기
답변 3개
가장 유용한 답변
From the model number you gave us, this appears to be the part you'll need:
https://www.amazon.com/pcspareparts-Repl...
cheers
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I need to replace the screen, this product offered is a protective case. So this did not answer my need. However, I may purchase a case in the future. Right now, I need a new screen.
의
This was helpful, but did nothing to correct the problem, However, I was prevented from answering no. So, this was most helpful for finding a protective item for my screen, but did nothing to replace the cracked screen.
의
Sharon,
The part I linked to you is what is called a digitizer. It sits between the display and your finger and allows you to "touch" objects on the display. If there is just crack on the screen and the display seems fine, you'll just need this part. If the screen shows discolored or distorted images, you will need to purchase a digitizer as well as an LCD display:
https://www.amazon.com/3CYYAP-Replacemen...
This will be an exceedingly difficult repair and will cost a lot for someone to repair for you. You are looking at a bill that could be easily twice or 3 times what the tablet is worth. Unfortunately, in this case, you will be better off getting a new tablet. :(
Cheers
의
댓글 달기
Okay so I literally just got this Tablet and I dunno what happened but the crack seems as if someone had stepped on it. I got it at Walmart and we got the warranty but I dont know if it supports broken screens which I'm assuming it doesn't. The funny thing is I'm twelve and I can't tell me grandma because I just got it last Monday. Yeah I'm irresponsible as !&&* but I really need help with this so could anyone help me?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Go to a Verizon store. they will fix it if they have the right size screen in stock. it is expensive, tho.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
also, ask them if they can check the insides to make sure that none of the curcuits or wiring is snapped or smashed.
의
댓글 달기
답변을 추가하세요
Sharon Jenson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 20
전체 시간: 2,795
