Why Is My Screen Flipped?
My Sharp Aquos smart tv (Model LC-55LE653U) has a flipped image (Upside Down). I can't find the flip feature on this model Is there a Service Mode to bring it back?
좋은 질문입니까?
좋은 질문입니까?
@repairking there should be a setting on your TV that is called Picture Flip. See if you can access it with your Sharp remote (not a Universal remote)
Press MENU
Scroll left or right to SETUP
Scroll up or down to PICTURE FLIP
Scroll up or down to STANDARD
Press ENTER
Press MENU
That should turn your picture normal. Let us know if it worked.
이 답변이 도움이 되었나요?
Didn't work there is no picture flip on my TV
Didn’t work no picture flip on my tv
dawngledhill paula.johnston456 if you are having a Sharp TV you will need the original remote.. How did you try it?
Hi @ paula.johnston456 @ dawngledhill,
If it happened after a recent update here's a link to an answer that may be of some help.
This works ...go to menu then quickly press 11 47, select item 7 on the panel...then item 9 ..brilliant
This worked for me.
Sharp lcd colour TV Model 32BB41
MENU straight after press 11471147
Scroll down to PANEL SETTING
Press mirror
이 답변이 도움이 되었나요?
I have replaced Nutec board in a Samsung plasma ,showing upside down pictures.
Pressing menue n 1147 shows factory setting without control pannel on the list.
Any one to help
We had an upside down picture after a brief power blip. I unplugged the TV, waited for about 20 seconds then plugged it back in. That fixed it.
이 답변이 도움이 되었나요?
지난 24시간: 5
지난 7일: 17
지난 30일: 43
전체 시간: 37,166
댓글 4개
Hi there. I have bush led smart TV the picture is upside down. I got up service menu but there is no mirror or flip options can you help me to get the picture back to normal in the right direction. Cheers
James skett 의
@James skett ,
What is the model number of the TV?
jayeff 의
Hi there I'm an electronics engineer, my flat screen TV VESTEL MODEL NO:VES315 WNDL-01, PICTURE UPSIDE DOWN BUT NO FLIPor MIRROR option. Pls how can I get the picture back to normal?
marcauley82 의
My tv has same problems but code dont work
IMZ Soykat 의
