주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon에서 제조한 프린터에 대한 수리 정보입니다.
Service code reset procedures
i have a S900 that had a Waste Ink Tank error indicated. I replaced the waste ink pads and now I cannot get the eprom to reset. When I turn it on the indicator light goes green then flashes 7 times.
The reset procedure is invloved and I think that may be why I haven't been able to get it reset.
Do you work on this old a printer?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 1개
I have a MG3520 it had a paper jam now my canon prints badley ive gone thu all the things that Canon told me to try by computer how can I reset the alinement manualy.
의 공유
댓글 달기
답변 2개
선택된 해법
Here's how to reset it:
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
Service/factory test printout, including ink sensor check
EEPROM info printout
EEPROM initialization
Clear the waste-ink counter
Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
this procedure doesnt work with canon pixma mg2545s
의 공유
I dont have a RESUME button All I have is a POWER,WIFI,PAPER SIZE BLACK,COLOR AND ON AND OFF BUTTONS THAT IS IT.
의 공유
this procedure doesnt work for me. i can set to service mode and thats all....
의 공유
댓글 달기
mine too doesn’t work,
model TS207, any solution?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
R genola 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 51
지난 30일: 123
전체 시간: 52,579
