주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 2세대. 모델 번호 A1241 / 8GB 또는 16GB 용량 / 검은색 또는 흰색 플라스틱 후면. 수리는 1세대 iPhone보다 더 간단합니다. 스크루드라이버, 여는 도구, 흡착 컵이 필요합니다.
Error 6 fix?
I've been trying to reinstall iOS 4.2.1 on my old 3G iPhone, but it throws back error 9 or 6 every time. I've already tried most of the common solutions. Can anybody offer any assistance? Thanks!
Update (06/17/2017)
I also forgot, it's stuck in DFU mode, and the iOS was corrupted when I got it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Try to flash with 3Utools
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
are you sure all the connections are fine? dock and cable I mean.
의
Yes, and I was doing it wrong anyway. :) I downloaded the actual program, and it fails at 13% saying invalid serial number.
의
This tool is very useful~ And about invaild serial number, you can try to enter your device to DFU mode and flash again.
의
댓글 달기
Your device is stuck on DFU, you can exit that with 3uTools.
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
With the serial number issue, it refuses to flash. It's also stuck in a somewhat damaged DFU mode, so the only way I can get it to even begin the process is by cheating with iTunes and unplugging it once it reenters recovery mode. I'm honestly a little stumped on this.
의
If serial number issue issue still exists, there may be hardware issue. You are suggested to get a repairman to check your device.
의
댓글 달기
답변을 추가하세요
Nikola Wozniak 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 24
전체 시간: 662
